• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    New Member
    13088
    Wood Carving
    186 Views, 4 Replies
    01-24-2013 10:02 AM
    Hi I am a highschool student and last year I started a Gothic style throne chair in a woodworking class. I first drew it up in Autodesk Inventor and then created job plan sheets for each individual part. This semester I plan to finish the throne. I want to incorporate gothic themed carvings (designed by me) into the throne. Our school owns a 3D Router so my plan was to create the 3D carvings and have the router cut them into parts of my throne. My question is what software I should use to create the carvings. Should I use Inventor?
    -Roy
    Please use plain text.
    *Expert Elite*
    blair
    Re: Wood Carving
    01-24-2013 12:28 PM in reply to: 13088
    If you have already modeled everthing in Inventor, all the pieces for the assembly, the next logical step would be to use the IPT's and import them into the CAM software for the NC 3D router.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    *Expert Elite*
    PaulMunford
    Re: Wood Carving
    01-24-2013 12:35 PM in reply to: blair
    You will want solid geometry for your CAM programming. This can be done in Inventor - see this film:
    http://youtu.be/awXh8Svs9nE
    You could use Fusion, 123D or AutoCAD - but you wouldn't maintain the parametric relationship with your inventor IPTs.
    The CAD Setter Out Blog
    @CadSetterOut
    Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
    *Expert Elite*
    Curtis_Waguespack
    Re: Wood Carving
    01-24-2013 01:15 PM in reply to: 13088
    Hi 13088,
    As a student I think you will learn a great deal in terms of technique by modeling some of the carvings in Inventor. But if you were to pursue this professionally or even as a serious hobby, you would want to be aware of other software that is dedicated to the CNC woodcarving industry, such as these examples:
    http://www.vectric.com/WebSite/Vectric/vcp/vcp_index.htm
    http://www.carve3d.com/index.asp?pageID=6
    http://www.vectorart3d.com/
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    New Member
    13088
    Re: Wood Carving
    01-24-2013 04:32 PM in reply to: Curtis_Waguespack
    Thanks a lot for all of your replys. The software the router uses is Cut3D which I believe is a product from Vectric. I will look more into this.
