Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Wiring and cable assembly / drawing
- Highlight
- Email to a Friend
- Report Inappropriate Content
I've been creating documentation for cable assembly for many years now and I am trying to determine a way to use the Inventor Cable and Harness feature to accomplish the same detailed drawings as I previously made by hand. The first thing I notice is that the connectors do not exist at the cable level, even though this is how they will be manufactured. Is there any way to generate a cable with wiring and connectors all existing together in an assembly that can then be documented in a drawing?
Re : Wiring and cable assembly / drawing
- Highlight
- Email to a Friend
Meaby I do not understand your needs but...
In an existing assembly (or new assembly...), put your connectors and then click on wire& hardness. Make your harness by linking the connectors with wires/cable... Then exit wire&harness add-on.
Now you can make a drawing of the assembly...
John.
Autodesk Product Design Suite Ultimate 2013
Win 7 Pro 64 bits SP1
Bi-Xeon E5520 (2x Quad-core @2.27GHz)
Quadro Fx 1800 768Mo GDDR3
6Go Ram DDR3 667MHz ECC
- Highlight
- Email to a Friend
John, I don't believe this would let me lay the cable out flat in the drawing though, would it? The only option for showing the full assembly is "in position", right? I was hoping that there was a way of showing the nailboard (?) view with connectors attached.
- Highlight
- Email to a Friend
I do not right undestood you would like to make a drawing of your harness only (nailboard) and not of your harness in position into your system.
To make a nailboard drawing then :
In your assembly, double-click to edit your harness.
then click on the nailboard icon and select your template for the drawing.
Now you are in a special menu for nailborad drawing... I'm not an user of the nailboard function but I now it's probably what you're looking for.
Have a good time with that function ![]()
Sorry, Can't add pictures to help you... My computer is boring me today ![]()
- Highlight
- Email to a Friend
No, Jonathan, I am not talking about nailboard or about a drawing showing the cable "in position into my system". What I would like is something in-between the two that shows the cable laid out (like drawing board) with the connectors in place (like in position into my system), so that I can show all components and cable lengths at once in one drawing view.
-Thom
- Highlight
- Email to a Friend
Could you provided an example (hand-drawing or something else) of what you would like to achieve for better understanding please?
Regards.
- Highlight
- Email to a Friend
Jonathan,
Here are some examples of a standard cable assembly I would create. Notice that the wires / cables are laaying straight, not like they would be in the installed state.
best regards,
Thom Friedrich
