• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Windows 8 black screen
    349 Views, 4 Replies
    12-08-2012 04:41 AM
    I am using Windows 8 with Inventor 2012 and have an issue with the Inventor windows going black only when I do a save. I am simply reporting this as I know Windows 7 is the recommended OS, even for Inventor 2013. However, it would be nice to know if there was a fix.  Nvidia apparently has no partner drivers for Windows 8 and I tried their Beta which didn’t help. I am running Intel’s i7-2700K with NVidia Quadro FX 3800. Thanks!
    Please use plain text.
    *Expert Elite*
    DarrenP
    Re: Windows 8 black screen
    12-08-2012 06:08 AM in reply to: Maxcn
    no inventor version is supported on windows 8
    does this happen on windows 7?
    Valued Mentor
    jclaidler
    12-10-2012 05:44 AM in reply to: Maxcn
    I don't believe Inventor 2012 is supported on Windows 8.  You can try to run in 'compatibility mode', that may resolve your issue.
    _______________________________________________________________
    ITO - Application Management
    Factory Design Suite Ultimate 2012
    AutoCAD 2012 | Inventor Professional 2012 | Vault Professional 2012
    New Member
    12-12-2012 10:55 PM in reply to: jclaidler
    To follow up I should explain that the black screen is a momentary occurrence; after I do a save all the windows flash to black and return to normal. It is just an annoyance. I have tried Windows 8 in compatibility mode, changed privilege levels and also changed the Inventor display quality settings to no avail.  I had no such troubles with Windows 7 but like 8 too much! Regards
    Valued Mentor
    stephengibson76
    12-13-2012 02:22 AM in reply to: Maxcn
    same here, on AutoCAD also...  its something I am willing to live with for the win 8 overall computer speed improvement and amazing lightning quick remote desktop i use all the time
    Stephen Gibson
    Autodesk Product Design Suit 2012
    Win 7 Enterprise 64bit
    Intel core i7 2600K Clocked @ 4.7GHz
    16Gb Ram
    Nvidia GTX 580
