Inventor Forum
Windows 8 and Inventor 2012
15 REPLIES 15
Message 1 of 16
stephengibson76
18281 Views, 15 Replies
We have a Samsung series 7 slate running windows 8.  The windows tablet was bought as an alternative to trying to convert all of our software to android to carry out surveys.
This has landed on my desk to explorey the possibility of running inventor on it as an emegency or travelling copy.  The installation completes but it only installs sketchbook designer and fails on the rest of the product design suite.  The system specs are below, ( i ran inventor 2011 on a lot worse)  is it the specs or is it simply windows 8?
  • 11.6in, 1366 x 768, glossy PLS screen
  • Core i5-2467M, 4GB RAM, 64GB SSD
  • USB 2, MicroSD, Micro HDMI (+HDMI, USB 2, Ethernet via dock)
  • Wacom digitizer and stylus
  • Wireless Bluetooth Keyboard, Media dock
Stephen Gibson
View stephen gibson's profile on LinkedIn
15 REPLIES 15
Message 2 of 16
kstate92
in reply to: stephengibson76
I would just assume the graphics chipset / drivers are something the IV installer aren't familiar with.  Or maybe a .Net versioning issue?
KState92
Inventor Professional 2020
AutoCAD Mechanical 2022.0.1
Windows 10 Pro 64 bit - 1903
Core i7-8700 32 GB Ram
Quadro P2000
Message 3 of 16
stephengibson76
in reply to: kstate92
thanks for the reply, it installed some .net components before it tried to install inventor.
the graphics is intel hd graphics 3000 which should be ok, I cant find much info
Stephen Gibson
Message 4 of 16
kstate92
So if this tablet was running Win 7, would IV install okay?  Good way to rule out the hardware at least.
KState92
Quadro P2000
Message 5 of 16
stephengibson76
I ran 2011 like a dog on a crappy old toshiba running windows 7
Stephen Gibson
Message 6 of 16
kstate92
I just meant I was curious if the new Samsung tablet hardware running non-beta Windows 7 would allow the IV install.  I don't think I being very helpful, though.
KState92
Quadro P2000
Message 7 of 16
DarrenP
its probably a .net issue
windows 8 comes with a newer version of .net
you may have to modify the .ini file
DarrenP
Message 8 of 16
kstate92
in reply to: DarrenP
4.5 it seems.
http://en.wikipedia.org/wiki/.NET_Framework_version_history#.NET_Framework_4.5_.28Upcoming.29
KState92
Quadro P2000
Message 9 of 16
stephengibson76
correct, its falling over trying to install .net 4
compatability mode doesnt work and I cant see a way to downgrade to .net 4
I can install mudbox from the usb key without going thru the setup program but that requires an ATI or nvidia card to run.  Inventor doesnt let me install it vwithout going thru the setup program
Stephen Gibson
Message 10 of 16
DarrenP
your going to have to modify the .ini to remove all the .net references:
http://forums.autodesk.com/t5/CAD-Managers/Anyone-try-Windows-8-Developer-preview/td-p/3349977/page/...
he did it for autocad 2012
DarrenP
Message 11 of 16
stephengibson76
passed it on with the link to our IT staff, will let you know if it works... got real work to do
thanks for all the replies
Stephen Gibson
Message 12 of 16
stephengibson76
that worked...  now, what do i do with it???
Stephen Gibson
Message 13 of 16
DarrenP
don't know
 i guess you can say you got it to work
DarrenP
Message 14 of 16
Installed full 3.5 NET package on win 8 64bit, have been trying inventor install for a while, tried un-ticking boxes except install for autodesk inventor and it seemd to do the trick. Dunk
Message 15 of 16
zubat
in reply to: sciencetechnician
Setup.ini for inventor/pro.... ;D without dot.net 4 (install the latest service pack, pls....)
Tags (1)
Message 16 of 16
Designer_514
Good afternoon everyone
What I did to make it working:
  1. Removed all Microsoft Visual C++ things obtained with Windows 8.1
  2. Installed the same Visual C++ software from Invenor installation folder.
  3. Installed Invenor 2012 and additional products
  4. Installed servise Pack 2 on Inv2012
  5. Installed the lates hotfix for Inv2012
  6. Was whooping out exitment when it started working
    BTW, i tried all methods above with no result, as well as other ways digged out on the Internet.
Perhaps, it likes personal aproach 🙂
