• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Re: Will my model break
    11-13-2012 04:15 PM in reply to: JDMather
    What is your safety factor?
    Are you intending displacement as intentional?
    If so, do you have a target displacement?
    Do you have a target pressure (or force)?
    Please use plain text.
    11-13-2012 04:19 PM in reply to: EdwardCChamberlain
    EdwardCChamberlain wrote:
    Ive attached a model. I want to apply pressure along the x and z axis to the top of the thinner rod. And then id want to know wether that rod would snap off
    Of course it will , or at least at some point)  bend over and not return to original condition.  Do you have some target parameters?
    11-14-2012 02:42 PM in reply to: JDMather
    For the X and Y one direction along either, it doesnt matter which because its round.
    And I want to work out at what force it will become deformed at. Ideally it would be good for it to be subjected to 2.5N and still be "good as new".
    My question is really how do i use the stress analysis and how do i interpritate the results
    11-14-2012 03:04 PM in reply to: EdwardCChamberlain
    It sounds like you need to hire an engineer.  Stress analysis isn't something you can learn from a discussion forum, or even a program tutorial.  You must have a solid mechanical engineering foundation to be able to decide if the results you get from the analysis are even worth anything.
    Stress analysis is all about making acceptable assumptions to simplify the model, and choosing the correct input to examine a specific problem.  If you don't understand the principles of mechanical design, you won't know which assumptions are acceptable, or which inputs are correct, or even if the results are close to reality.
    11-15-2012 10:09 AM in reply to: cwhetten
    ok thanks, i cant afford to do that im a student!! i guess ill just for the make it and then poke it to see if its good approch :smileyhappy:
    Thanks Ed.
    11-15-2012 11:45 AM in reply to: EdwardCChamberlain
    Nothing is better than prototyping and physical testing!  :smileyvery-happy:
