Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Will my model break
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What is your safety factor?
Are you intending displacement as intentional?
If so, do you have a target displacement?
Do you have a target pressure (or force)?
Inventor Professional 2014 Edu 64-bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
EdwardCChamberlain wrote:Ive attached a model. I want to apply pressure along the x and z axis to the top of the thinner rod. And then id want to know wether that rod would snap off.
Of course it will , or at least at some point) bend over and not return to original condition. Do you have some target parameters?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
For the X and Y one direction along either, it doesnt matter which because its round.
And I want to work out at what force it will become deformed at. Ideally it would be good for it to be subjected to 2.5N and still be "good as new".
My question is really how do i use the stress analysis and how do i interpritate the results?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It sounds like you need to hire an engineer. Stress analysis isn't something you can learn from a discussion forum, or even a program tutorial. You must have a solid mechanical engineering foundation to be able to decide if the results you get from the analysis are even worth anything.
Stress analysis is all about making acceptable assumptions to simplify the model, and choosing the correct input to examine a specific problem. If you don't understand the principles of mechanical design, you won't know which assumptions are acceptable, or which inputs are correct, or even if the results are close to reality.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
ok thanks, i cant afford to do that im a student!! i guess ill just for the make it and then poke it to see if its good approch
Thanks Ed.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Nothing is better than prototyping and physical testing! ![]()
