• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Will my model break
    300 Views, 15 Replies
    11-12-2012 03:58 PM
    I've created a model in inventor that is a plate with two pins coming off of it. (Made from ABS)
    what i was wondering was weather there was a way to test wether the pin would snap when a force is aplied to it? I'm also interested in how much it will flex But it isn't essential.
    how can I do this in inventor??
    Thanks Ed. :smileyhappy:
    Please use plain text.
    *Expert Elite*
    Cadmanto
    Re: Will my model break
    11-12-2012 05:32 PM in reply to: EdwardCChamberlain
    Ed,
    You would have to do a stress analysis in Inventor.
    What version of Inventor do you have?
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    11-13-2012 09:40 AM in reply to: Cadmanto
    im using 2013, will have a look at that link. so far ive only managed to make it bend the part? :smileyfrustrated:
    11-13-2012 09:55 AM in reply to: Cadmanto
    so as i understand if i see red anywhere in my simulation: It will break?
    Ed.
    *Expert Elite*
    11-13-2012 09:55 AM in reply to: EdwardCChamberlain
    Attach your file here.
    Inventor does not do fracture analysis.
    It will show you where part goes beyond elastic deformation into plastic deformation.
    11-13-2012 10:16 AM in reply to: JDMather
    Regretably i cant attach the actual design file but i will attach a demonstration piece when i get back to my computer.
    So the plastic deformantion is a permenant change? Whereas elastic deformation is reversable? If so then i would require no plastic deformation.
    Thanks Ed.
    11-13-2012 01:51 PM in reply to: EdwardCChamberlain
    Ive attached a model. I want to apply pressure along the x and z axis to the top of the thinner rod. And then id want to know wether that rod would snap off.
    Thanks Ed.
    *Expert Elite*
    11-13-2012 01:57 PM in reply to: EdwardCChamberlain
    There is no material assigned.
    Inventor doesn't do fracture analysis.
    11-13-2012 03:18 PM in reply to: JDMather
    it should be assigned ABS plastic, and ok is there a way of finding out wether it will be irreverably dammaged?
    *Expert Elite*
    11-13-2012 04:07 PM in reply to: EdwardCChamberlain
    Thanks Ed.
     Along the x and z where?  Equal in each direction?
