• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Why does the camera turn 180 degrees after selecting top plane
    283 Views, 3 Replies
    01-11-2013 04:12 AM
    I use inventor 2013. Whenever I start a new sketch and select the top plane, the camera changes so I look at the top plane but also rotates 180degrees. I really hate that the camera rotates 180 degrees because it causes me to always see the drawing upsidedown (and then change the camera... everytime...)
    Is there a way to disallow inventor to cause this treason?
    Kind regards,
    Gerard
    Please use plain text.
    Re: Why does the camera turn 180 degrees after selecting top plane
    01-11-2013 04:18 AM in reply to: SlechteExcusesMan
    Im not sure if this is what you mean, but go to Tools>Application Options>Sketch Tab, and uncheck "Look at sketch plane on sketch creation" towards the bottom on the left.
    New Member
    01-11-2013 04:31 AM in reply to: riff62
    I do want to look at the sketch plane but I don't want inventor to also turn the camera 180 degrees so my plane is upside down
    I've added an attachment. The right part of the image shows what my viewcube looks like after I started a drawing on the top plane, the left part of the image shows what I want my viewcube to look like
    Active Member
    01-30-2013 10:53 AM in reply to: SlechteExcusesMan
    +1.  Asinine problem, been around for years, has a seemingly immediate and simple fix.  Fix the problem, please.
    "Idea" post:
    http://forums.autodesk.com/t5/Inventor-IdeaStation/Sketch-Orientation-quot-Look-At-quot-Feature/idi-...
