Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Why does my derived part turn into a surface part?
- Highlight
- Email to a Friend
I am deriving a part from an assembly. After I remove parts that I don't want included in the derived part, the part is automatically switching to a surface part. I was initially trying to use the hole and extrude functions and kept getting errors. I saw that the part was being made into a surface part. How can I fix this? Thanks in advance!
I'm running Autodesk Inventor Professional 2013.
Intel Xeon W3680 @ 3.33Ghz
12GB DDR3 RAM
NVIDIA Quadro 2000 GPU
Windows 7 Professinal 64-bit
Re: Why does my derived part turn into a surface part?
- Highlight
- Email to a Friend
When you Derive Component there is an option to derive as Solid or Composite Surface. I think the default is as Composite Surface body. SImply edit and change.
- Highlight
- Email to a Friend
I've tried to edit the part, but composite surface wasn't selected. I had derived other parts before this one and they came out fine. It just seems to be this part. I never changed the setting either.
12GB DDR3 RAM
- Highlight
- Email to a Friend
Attach the files here.
- Highlight
- Email to a Friend
It turned out that a weld was causing the problem. Once I excluded the weld from my part, it worked fine.
12GB DDR3 RAM
