• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Why does my derived part turn into a surface part?
    163 Views, 4 Replies
    11-12-2012 12:09 PM
    I am deriving a part from an assembly. After I remove parts that I don't want included in the derived part, the part is automatically switching to a surface part. I was initially trying to use the hole and extrude functions and kept getting errors. I saw that the part was being made into a surface part. How can I fix this? Thanks in advance!
    I'm running Autodesk Inventor Professional 2013.
    Intel Xeon W3680 @ 3.33Ghz
    12GB DDR3 RAM
    NVIDIA Quadro 2000 GPU
    Windows 7 Professinal 64-bit
    Please use plain text.
    *Expert Elite*
    Re: Why does my derived part turn into a surface part?
    11-12-2012 01:04 PM in reply to: hhls11
    When you Derive Component there is an option to derive as Solid or Composite Surface.  I think the default is as Composite Surface body.  SImply edit and change.
    11-12-2012 02:50 PM in reply to: JDMather
    I've tried to edit the part, but composite surface wasn't selected. I had derived other parts before this one and they came out fine. It just seems to be this part. I never changed the setting either.
    12GB DDR3 RAM
    *Expert Elite*
    11-12-2012 03:21 PM in reply to: hhls11
    Attach the files here.
    11-14-2012 12:24 PM in reply to: JDMather
    It turned out that a weld was causing the problem. Once I excluded the weld from my part, it worked fine.
    12GB DDR3 RAM
