• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Why No Fusion Ribbon Panel?
    302 Views, 9 Replies
    04-27-2012 10:49 AM
    I was trying to show another user the Edit in Fusion feature in Inventor 2012 but she doesn't have that ribbon panel.  We went into the Part tab in Application Options and Inventor Fusion was selected to Edit Base Solids.  We even unselected it, applied it, closed the options and then selected it again.  But still there is no Fusion panel under the Model tab when editing a part.  Yes, it's installed on her machine.  We checked.
    The only difference is that she's also installed the 2013 suite, as well.  I have the Fusion panel and have not installed any 2013 apps.
    Bill Schmid
    Autodesk Product Design Suite Premium 2013
    Autodesk Vault Professional 2013
    Dell Precision T1650
    Windows 7 Professional SP1 64-bit
    Intel E3-1270 V2 3.5GHz / 32G RAM
    Nvidia Quadro 2000, Driver 311.06
    256 GB SSD
    Space Navigator, Driver Version 6.16.1
    Please use plain text.
    Re: Why No Fusion Ribbon Panel?
    04-27-2012 11:10 AM in reply to: Bill.Schmid
    Try right clicking somewhere in the browser.
    Do you get an option to edit in Fusion?
    Inventor Professional 2014 Edu 64-bit
    04-27-2012 11:20 AM in reply to: JDMather
    No.  She cannot access the Fusion feature in any way, shape, or form (no pun intended).
    I was thinking it was because it was a solid created from an imported surface, but I had an empty part open on my machine and at least the panel was there, it was just greyed out.
    I had her try right-clicking in the empty area of the ribbon to make sure the panel wasn't just turned off, but the option just isn't there.
    It's not available / doesn't show up in the Add-In Manager, either ( I missed that part of your post, initially).
    Bill Schmid
    256 GB SSD
    04-27-2012 11:24 AM in reply to: Bill.Schmid
    Show a screen shot of your Add-in Manager.
    04-27-2012 01:04 PM in reply to: Bill.Schmid
    It looks just like what you posted except Fusion Freeform Edit Launcher is missing.
    Bill Schmid
    256 GB SSD
    Mark_Flayler
    04-27-2012 02:56 PM in reply to: Bill.Schmid
    Does she have Fusion 2012 or 2013 installed?  If you only have 2013 in there then it will not show up in 2012.  Fusion integration is version specific.
    Mark Flayler Application Engineer - Manufacturing Solutions Division
    IMAGINiT's Manufacturing Solutions Blog:
    http://blogs.rand.com/manufacturing/
    04-30-2012 03:42 AM in reply to: Mark_Flayler
    She has Fusion 2012.  We checked that.
    We did not check specifically to see if Fusion 2013 was installed, but she did do a full install on Product Design Suite Premium 2013, so it should be.
    Bill Schmid
    256 GB SSD
    CAD-One
    04-30-2012 04:21 AM in reply to: Bill.Schmid
    My colleague has this very same issue. Can't access fusion thru inventor
    C1
    Inventor Professional 2013
    Vault Collaboration 2013
    Employee
    04-30-2012 07:32 AM in reply to: CAD-One
    As mentioned above, make sure that you have the same version of Fusion and Inventor (2013 for both). I have PrDS Ultimate 2013 installed and it works for me. If possible, try an uninstall then reinstall of Fusion. The add-ins install with Fusion if it detects that Inventor is installed.
    You might also try the Inventor Fusion discussion groups too.
    Patrick Miller
    Senior Content Developer
    04-30-2012 07:46 AM in reply to: patrick.miller
    I think we're going to let it go.  It was a one-time occurence where she could have either edited a simple imported part in Fusion or re-modeled it.  It was faster to remodel, in this case, than to try to re-install software.  Besides, we should be switching to 2013 soon.  Thanks.
    Bill Schmid
    256 GB SSD
