• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Where to give the revision number
    157 Views, 2 Replies
    11-29-2012 11:00 PM
    Where to give the revision number to get automatically update.now my revision is zero, now i wanna make to revision 1. how to change  ?????.
    Please use plain text.
    Valued Mentor
    Re: Where to give the revision number
    11-30-2012 08:00 AM in reply to: viveksriramr
    if the revision in your title block is taken from your idw iProperties then you can put the revision value into the iProperty directly.
    if you place a revision table on your idw then right click on the table and choose "add revision" then it will bump the revision in your iProperty and at the same time you will see your title block update.
    if the title block defenition does not read the iProperty then you can edit the title block definition, edit the rev text within that, and add the value to read from the idw iProperty.
    try to just hit F1 (help) for more information whilst ininventor and while in the command, or search inventor wiki help for some more info.
    -Mark
    Inventor 2014 Pro on Windows 7, 64bit
    (please give Kudos or Tag as Solved if your issue is resolved)
    Cadmanto
    11-30-2012 11:47 AM in reply to: viveksriramr
    Like Mark has outlined in setting up the revision to be property driven, if you have vault
    you can have this revision update automatically if you bump the revision level in the vault.
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
