After installing the FULL Local Help file and searching WikiHelp for 2012, I am unable to find the API Help files. How do I access help files for the Inventor 2012 API?
Full Local help file indicates that it should be found under Programming within the Additional Resources folder neither of which currently exist. I'm expecting to see entries similar to Inventor 2011.
Thank you in advance for your assistance in this matter.
Solved by SBix26. Go to Solution.
Look in the help_lite folder, under the Inventor installation directory.
You should see a file named "admapi_16_0.chm". This is the API documentation for 2012.
Jeff
Thanks Sam for your reply to my question. While Mr.. Pek's answer does work, I thought that there would be a simpler way to access the help for Inventor 2012 API information. Your screenshot says it all!
