• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Where is dimension d1 in Inventor 2013?
    662 Views, 11 Replies
    08-09-2012 07:48 AM
    Hi
    I have been using the new version of Inventor for a fews weeks, and creating a new part model this afternoon I have noticed that the dimension d1 no longer exists.  Has anyone else spotted this or had this problem?
    To explain the problem in more detail.  I open a new part file (either our company's template or the standard Inventor template), then in Sketch1 I draw a fews lines and pull some dimensions from these.  The first dimension I create is called d0, the second dimension I create is called d2.  The dimension d1 is totally skipped.  I'm not deleting anything just simply starting in a brand new file.
    Obviously I would understand it if the first dimension was called, for example, d7, then this would illustrate that the original template file had been saved over.
    Thank,
    Please use plain text.
    rhasell
    Re: Where is dimension d1 in Inventor 2013?
    08-09-2012 04:19 PM in reply to: 909chubb
    Hi
    Never noticed, if I may ask why is this a problem?
    If you are using the dimensions in predefined formulas or caclulations, it is better practice to give the dimensions a meaningfull name.
    Create a User parameter of "LENGTH" for example, to make the parameter available in other areas and part, tick the check box "Export Parameter"
    Now instead of refencing "d0" or "d1" etc, you can refer to "LENGTH", "WIDTH" etc.
    Regards
    Reg
    Autodesk Product Design Suite Premium 2013 sp1.1 (1)
    Intel Core i7 (950@3.07GHz)
    Windows 7x64 (Home)
    12GB Ram
    Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
    *Expert Elite*
    08-09-2012 04:30 PM in reply to: 909chubb
    If I enter the dimensions as dynamic in the direct distance hitting tab for a rectangle it does d0 d1
    if instead I click with the mouse the corners and then dimension I get the d0 d2 behavior you see.
    If I create two lines and then dimension I get the d0 d1
    Never paid 1 tenth of a second attention to d numbers before you bringing this to attention.
    08-10-2012 12:41 AM in reply to: rhasell
    Hi rhasell
    There are several reasons why I prefer using the d# designations rather than renaming the parameter.  Firstly we tend to create many more new parts than using our own custom part library.  I find the whole business of renaming dimensions time consuming with little benefit, specifically because the once or twice I have tried it, I have spent more time trying to think up imaginative and descriptive dimension names than actual designing.  Another reason is the size of a dimension formula is smaller when using d0, d1, etc, this means all of the formula is more likely to be visible in the mini dimension window and in the iproperties box.
    To answer your first question (sorry if this sounds abrupt), "why is this a problem?"  We are all engineers and I believe the smallest detail is as important as the largest generalisation.  This is an engineering program, how can dimension d1 be missing?  And don't even mention the newly revised material and appearance feature!
    Employee
    MingweiGao
    08-10-2012 02:14 AM in reply to: 909chubb
    Yes, I can reproduce your problem on my machine and we will do some investigations about this issue.
    Thank you!
    Mingwei Gao
    Software QA Engineer
    Inventor Quality Assurance Team
    Employee
    MingweiGao
    08-28-2012 12:12 AM in reply to: MingweiGao
    Hi, this issue has been tracked in our internal system and the issue number ID is 1467766.
    Mingwei Gao
    Member
    wfbbob
    02-04-2013 04:24 PM in reply to: 909chubb
    Has there been a "fix" for this d1 issue?  Is there a way around it?
    *Expert Elite*
    02-04-2013 05:16 PM in reply to: wfbbob
    Why is it an "issue"?
    Valued Mentor
    02-04-2013 05:26 PM in reply to: 909chubb
    Totally agree with you on all counts. I too had stopped renaming dimensions long time ago and use 'd#' instead. To give the dimension some meaningful description I use "Comments" column in Parameters DB when it is necessary.
    Best Regards,
    Igor.
    909chubb wrote:
    Hi rhasell
    Web: www.meqc.com.au
    *Expert Elite*
    blair
    02-04-2013 08:23 PM in reply to: IgorMir
    I agree, unless you have a specific template such as a Sheet-Metal template, certain 3rd party add-in (such as NC Profile burning) look to group items for nesting based on thickness and Material there is no reason to rename parameters.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
