• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Accepted Solution
    When I export to STL. format, the dimensions are incorrect
    200 Views, 4 Replies
    01-28-2013 01:25 PM
    When I export a file into STL. format, and then open that STL. file back in Inventor, the file has scaled to the wrong dimensions. Am I exporting it incorrectly? What am I doing wrong?
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: When I export to STL. format, the dimensions are incorrect
    01-28-2013 01:32 PM in reply to: gsger5
    Hi  gsger5,
    Assuming you're using Inventor 2011 or later, you can click the Options button when exporting the STL file and set the units in the resulting dialog box. Note that there was a bug with this option in Inventor 2012, but Service pack 1 fixed it (if I recall correctly).
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    01-28-2013 01:51 PM in reply to: Curtis_Waguespack
    Can't believe I over-looked that, thanks! This should solve my problems.
    How do I scale a part up?
    01-28-2013 02:47 PM in reply to: Curtis_Waguespack
    I need to scale a part up by 2, I'm not sure how though.
    *Expert Elite*
    Re: How do I scale a part up?
    01-28-2013 02:56 PM in reply to: gsger5
    Start new file and Derive Component and select Scale.
