• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    ryansmalley
    When I create a simulation the stress analysis ribbon doesn't enable options.
    532 Views, 4 Replies
    08-07-2011 04:03 PM
    What do I need to do to enable the stress analysis buttons? Please answer with screen shots if possible, it would help to see where to click and what to do. Thanks
    I am using  Autodesk Inventor 2012 proffesional.
    Please use plain text.
    *Expert Elite*
    Re: When I create a simulation the stress analysis ribbon doesn't enable options
    08-07-2011 05:15 PM in reply to: ryansmalley
    Show a screen shot of your Environments tab.
    Sown a screen shot of your Tools>Addins
    Active Member
    ryansmalley
    08-18-2011 04:51 PM in reply to: JDMather
    Here are the screen shots, please help.
    *Expert Elite*
    08-19-2011 05:14 AM in reply to: ryansmalley
    Have you gone through the getting started tutorials for using the Ribbon Interface?
    It appears you have set to Compact rather than Normal (see attached image).
    Right click on a tab and set Ribbon Appearance to Normal.
    Or is something else your problem?
    Why does it take 11 days to post requested information?
    Active Member
    ryansmalley
    08-19-2011 01:00 PM in reply to: JDMather
    The problem is when I mouse over the buttons the menu underneath is grayed out. Like when I mouse over the loads button everything underneath is grayed out and I cannot click on anything.
