• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Expert Elite*
    Cadmanto
    Accepted Solution
    What are these Symbols?
    254 Views, 4 Replies
    11-06-2012 07:33 AM
    Can someone tell me what these are and what they are used for?
    I am thinking they are imate symbols of some sort.
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: What are these Symbols?
    11-06-2012 07:49 AM in reply to: Cadmanto
    Hi Cadmanto,
    You're correct, those are iMate glyphs/symbols. Most Content Center parts have them by default.
    http://wikihelp.autodesk.com/Inventor/enu/2013/Help/1310-Autodesk1310/1655-Assembli1655/1656-Build_a...
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    *Pro
    11-06-2012 07:51 AM in reply to: Cadmanto
    They are iMate glyphs.  Whatever you have selected in that view has a couple of Mate iMates and a couple of Insert iMates.  If you alt-drag one of those glyphs to geometry that fulfills the other half of that constraint type, it will constrain without the need for a dialog box.  Very useful with screws, for example.
    *Expert Elite*
    Cadmanto
    11-06-2012 10:03 AM in reply to: sbixler
    Thanks Sam.
    Didn't know about the alt key.
    I know now when I am inserting from the CC (hardware) it used to automatically constrain when
    the mating surface was selected or hovered over.  Not sure why it is not doing it now.
    Best Regards,
    Scott McFadden
    *Expert Elite*
    Cadmanto
    11-06-2012 10:07 AM in reply to: Curtis_Waguespack
    Thanks for the link Curtis.
    That confirms what I thought they were.
    I saw the ctrl-shft-Q to toggle the Mate-Glyphs but I am not seeing a way to toggle these white dots
    all over my screen on/off.
    Best Regards,
    Scott McFadden
