• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    josueocon
    Were are the Tube and Pipe Tutorials for Inventor 2012?
    1983 Views, 3 Replies
    07-21-2011 11:21 AM
    I just installed the 2012 invnetor  and was going trew the Tutorials and is not able to see any  like in (inventor 2011).
    Please use plain text.
    Curtis_Waguespack
    Re: Were are the Tube and Pipe Tutorials for Inventor 2012?
    07-21-2011 11:28 AM in reply to: josueocon
    Hi josueocon,
    They are online for download in 2012:
    http://inventortrenches.blogspot.com/2011/04/where-are-inventor-2012-tutorial-and.html
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Active Contributor
    josueocon
    07-21-2011 11:43 AM in reply to: Curtis_Waguespack
    I did that allready, but inventor wants to connect to internet everytime for the tutorial and I still can not to see the tutorials am looking for(more like hose routing)
    Employee
    07-22-2011 09:40 AM in reply to: josueocon
    Hello josueocon,
    If you have an Internet connection, Inventor 2012 is designed to take you to the tutorial pages on the Autodesk Wiki. Here is a link to the Tube & Pipe tutorials on the Wiki.
    http://wikihelp.autodesk.com/Inventor/enu/2012/Help/2144-Tutorial2144/3052-Tube_and3052
    Are you unable to access the Autodesk Wiki? Or do you not want to be connected to the Internet when performing the tutorials?
    Best regards,
    -Ted
    Ted Saufley
    Principal Content Developer
    DLS Manufacturing Engineering
