Autodesk Inventor
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Welds and Design Views
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
98 Views, 1 Replies
09-05-2011 04:33 PM
I have a weldment model. Would like to be precise in showing the welder the order of assembly and welding. I have defined design views, turning off components as we go through the weld process. I would also like to turn off visibility of welds that are on parts that are not visible. I can not seem to do that in the model or drawing, I do lock the view, when I get the state I want. Any suggestions?
Thanks in advance.
Re: Welds and Design Views
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
09-06-2011 04:55 AM in reply to:
Billduck
As you know by default Inventor have hability to show the process of welding. When you place a drawing in a sheet you can specify in dialog box which weldment process you need to show (assembly; machining; weldment or preparation). Unfortunately when you choose the assembly process you will get all the welds visibility off.
To do what you want you can manually hide the weld bem, one by one. To do that you need to activate the selection filter "Part Priority" to be able to select the welds. Then right click and "Visibility". See the image.
hope help
Maria Manuela Pinho
Application Enginner
Cadtech.Asidek | Autodesk Gold Partner
http://cadtech-asidek.blogspot.com/
www.cadtech.pt | www.cadtech.es | www.asidek.es
Autodesk Inventor Professional 2013
Windows 7 Professional 64-bit
