• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    blair
    Re: Weldment
    10-28-2010 08:59 AM in reply to: ijc
    You will probably have to do a Split-Face on the riser pipe. This will give a funny result at the points on the riser pipe.
    Your Split-Face line will start at the end-point of the cope of the Riser pipe.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Please use plain text.
    Valued Contributor ijc
    Valued Contributor
    ijc
    Re: Weldment
    10-28-2010 02:18 PM in reply to: blair
    Thanks Blair...IJC
    New Member
    eih5
    Re: Weldment
    11-17-2012 04:52 PM in reply to: ijc
    Did you ever figure this out?
    I am dealing with exactly the same problem, putting weldments on two pipes of same diameter.  I tried to use Split-Face but couln't get this to work. Help would be very much appreciated.
    Einar
