Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Weldment
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The file attached contains a main pipe with 4 flanges mated onto the pipe.I have not used the Weldment feature before so would please like some guideance and help.What steps would i use to Weld the 2 small upright pipes on top of the main pipe and Weld the 4 flanges onto the 4 small curved pipes underneath the main pipe?
Any help appreciated.....IJC
Re: Weldment
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
First, you need to either convert this existing model to a Weldment, or start a new model as a weldment. Then enter the Weld Module. The rest is straight forward, or read the "Help"
IV2014.1 PDSU / Sim Mech 2014 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 314.07
SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
Re: Weldment
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Blair...thanks for the reply....will take your advice and follow.
Blair is also possible to use Weld where i attached the 4 flanges onto the curved pipes under the main pipe?
Best Regards
IJC
Re: Weldment
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes, it's done the same way.
Win7-64
Re: Weldment
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you
Re: Weldment
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I was able to weld the 2 end pipes but was not able to weld the middle pipe.I used the same technique as the 2 end pipes but could not get it to work.I also tried some other welds but again would not work...What technique is required to weld the middle pipe onto the bottom pipe?
Thanks....IJC
Re: Weldment
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Your IAM file is useless without the required IPTfiles
Win7-64
Re: Weldment
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Here is the file..thanks
Re: Weldment
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The files you sent only contain a single part "Part1" and it's a flat plate with a slot and a couple of other holes.
Win7-64
Re: Weldment
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Will this picture help..The large pipe in the middle without the weld is the one i cannot get to work... Both pipes are 3" in diameter...thanks again
