• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    *Caldwell, Larry
    Re:
    11-14-2002 01:08 AM in reply to: rstadler
    Wonder if Leonardo could write "the perfect CAD
    package" anyone know his number? <G>
    ~Larry
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    Yes it's a 2 step process...
    If you can find the perfect CAD package that does
    EVERYTHING then yes...(and be sure to tell us what it is..)
    Sean Dotson, PE
    href="http://www.sdotson.com">http://www.sdotson.com
    ...sleep is for
    the weak..
    You
    put your left foot in, you put your left foot out, you chuck IV6 out the
    window and buy something else...
    Please use plain text.
    Valued Contributor
    Re:
    11-14-2002 01:21 AM in reply to: rstadler
    All in all, I'm not to terribly disatisfied w/ IV6. It just seems like they missed a few BASIC things (and keep missing them through all the releases). A SIMPLE way to mirror an assembly is a good example. Hopefully SP1 will be the answer to all your prayers - we'll find out tomorrow if the Autodesk server doesn't overload. My other question still remains... are you supposed to be able to include the same IPT into different weldment IAMs and machine them w/o this persistance error?
    *Allen, Albert
    Re:
    11-14-2002 01:23 AM in reply to: rstadler
    I have found that if I make a derived part from an
    assembly to use as a mirrored assembly I will use the same file name as the
    assembly and just tack on "for derived" to the end of the file name. This way I
    can easily find it but I can also easily tell that it's just a reference or
    "dummy model" and not to use it for anything. Just my 2 bits worth.
    ~Larry
    does EVERYTHING then yes...(and be sure to tell us what it
    is..)
    Sean Dotson, PE
    ...sleep is for
    the weak..
    You
    else...
    *Hinterhoeller, Richard
    Re:
    11-14-2002 01:31 AM in reply to: rstadler
    As Charles Bliss pointed out a while ago when this topic was raised, at
    what point do you stop mirroring.
    Do your right hand threads become left hand threads?
    What about a mirrored assembly where the same components are used, but
    just re-oriented? Do we want IV to generate a whole set of duplicate
    parts that are just mirror images of the original?
    If it were as easy as it initially sounds, I expect we'd have had the
    tools already.
    Just being the devil's advocate.
    Richard
    Valued Contributor
    Re:
    11-14-2002 01:39 AM in reply to: rstadler
    You (or Charles) make a good point. I had not thought about threads (although I suspect the right answer for 99% of us is No, you don't mirror threads). Rick
    *Puschner, Michael
    Re:
    11-14-2002 01:57 AM in reply to: rstadler
    I also would like to have a function for mirrored
    assemblies.
    But I think it's not that easy. Some parts in a
    mirrored assembly
    have to be mirrored parts. But what do you want to
    get if
    a part in the mirrored assembly is identically to
    the one
    in the original assembly? Similar
    face=Arial size=2>parts with different part
    numbers? What should happen
    size=2>to Fasteners?
    (What's about mirrored Fasteners with
    face=Arial size=2>left
    hand threads in the mirrored assembly?
    <g>)
    You see what I mean?
    Michael
    Puschner
    mp@scholle.de
    All
    persistance error?
    Distinguished Contributor
    Re: Weldment Assemblies w/ common subparts
    11-14-2002 08:45 PM in reply to: rstadler
    Just to add to Rick a little. What we would like to do and I think may work for him is to mirror the orientation of components in an assembly to create a new assembly. So the argument of threads is a valid one, but that would create new and unique part numbers.
    An example would be a V-8 engine. The valve covers have 4 bolts on top symmetrically placed and 5 on the bottom symmetrically placed. Thus the and bolts that hold the cover on are identical, it's just that there orientaion is mirrored about the centerline of the engine. The parts don't mirror, just their orientation.
    Just a wish item.
    *Dotson, Sean
    Re:
    11-14-2002 09:44 PM in reply to: rstadler
    On a Ford maybe...Mid 70s Chevy has 2 on top and 2
    on bottom, but you do have a point...<g>
    Sean Dotson, PE
    ...sleep is for the
    weak..
    Just
    Just a wish item.
