• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    slphantom
    Weird border problem
    55 Views, 0 Replies
    02-08-2012 02:39 PM
    for the past month or so I have been having this problem with my borders in idw's. it does not happen all the time and there seems to be no pattern to it. For instance I have a job with 4 sheets in an idw. 2 of them E size and two of them D size. Sometimes when I open the idw's all the borders are E size but on the sheets that are supposed to be D all the title block info is still in the correct place?? So I have to "edit sheet" pick another size then do it again to select D size again and it is fixed. Today another interesting thing popped up, I was converting to autocad ( I have to open them again to save them down to a earlier version) on one job all the D size sheets had the E border. I went back into the Inventor idw and everything was fine?? I Have used these templates for years and never a problem.
    any suggestions?
    Scott
    win 7 64 bit
    xeon cpu 3.2 GHz
    quad core
    12 gig of ram
    Autodesk product design
    suite premuim 2012 64bit
    Nvida quadro fx3800
    Space Pilot ver. 1.6.2 2010
    slphantom (NNTP handle: scottl)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as scottl
