• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Visible Sketch Dimensions on Face of Part
    105 Views, 2 Replies
    01-08-2013 01:19 PM
    Hello Users,
    I'm making a part and am adding features to it and using my existing sketch dimensions as my guide. The problem is that when there are sketch dimensions on the face of the part, they are difficult to read. I'm forever dragging these dims to the side in order to read them, it's just a bit annoying. I was wonering if there was a setting that made them show up as well as they do when the aren't sitting on the face of my parts. I've attached a .jpg of what I'm talking about. Please notice the dimension on the left side and the bottom. Can anyone suggest a solution? Thank you for your help.
    Please use plain text.
    Re: Visible Sketch Dimensions on Face of Part
    01-08-2013 01:34 PM in reply to: blburson
    The only thing I can suggest is make the text larger Tools>Application Options>General tab Annotation Scale.
    Inventor Professional 2014 Edu 64-bit
    Active Member
    01-09-2013 10:41 AM in reply to: JDMather
    That worked! Thank you so much!
