• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Anthony
    Visibility of objects in detail view
    132 Views, 2 Replies
    08-22-2012 05:47 AM
    Hi. I have a blown out detail on one of my Inventor drawings, I would like to toggle the visibility of some parts in this detail view however when I RHMB these under the browser I can't turn off the visibility, please could someone tell me how to do this. Thanks
    Please use plain text.
    *Expert Elite*
    Re: Visibility of objects in detail view
    08-22-2012 09:28 AM in reply to: Anthony
    Is the visibility option grayed out?  If so, this means you have the drawing view associativity set to a view representation.  If you don't know what that means, I would suggest you read up on view representations, as they can be quite useful.  Among other things, they allow you to control the visibility of components in an assembly and corresponding drawing views.
    As a quick fix, edit the drawing view and either set the view representation to Master, or uncheck the associativity box (see image).  This will allow you to manually control the visibility of components in a drawing view.
    Anthony
    08-23-2012 01:43 AM in reply to: cwhetten
    Hi. Many thanks for this, by unchecking the 'associative' box I am able to now toggle visibility of objects in the detail view without affecting the parent view. :smileyhappy:
