• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    View updates
    104 Views, 3 Replies
    05-04-2012 05:08 AM
    Hallo there.
    Is there a way to stop my drawing views from updating when I make a change to my assembly? I have assemblys of boxes that I need to make different views from but everytime I open the door to show an inside view it screws up my other views.
    Regards
    Bobeep
    Please use plain text.
    mrattray
    Re: View updates
    05-04-2012 05:13 AM in reply to: Bobeep
    I think you need to do some reading about view representations.
    Mike (not Matt) Rattray
    jtylerbc
    Re: View updates
    05-04-2012 06:32 AM in reply to: mrattray
    And depending on whether you're actually opening (moving) the door or just turning its visibility off to visually remove it, you might also want to look at positional representations.
    John Tyler
    Inventor 2013
    Windows 7 64 Bit
    Employee
    Re: View updates
    05-04-2012 01:21 PM in reply to: Bobeep
    I am sorry that I may not fully understand your workflow here. But, it sounds like you might have created some drawing views from upper level assembly when all you need is the views of the subassembly. Would creating subassembly view help here? Could you attach an image here or an assembly showing the problem you have?
    Thanks!
    Principal SQA Engineer, Inventor
    Manufacturing Group
