• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    brmanders
    Accepted Solution
    Vault Add-in Grayed out
    809 Views, 3 Replies
    06-15-2010 05:45 AM
    Yesterday, at what appeared to be random, all of my addins decided not to load into Inventor.  I noticed this as I could not place parts from content center or Vault.  I changed them back to "Startup/Loaded" under "Load Behavior" in the Add-in manager and restarted inventor.  Content center and the Vault tab are now appearing on my ribbon.  The problem is all the vault commands are "grayed out" (i.e. unselectable).  Also, the "place from vault" command is back for assemblies but when clicked, nothing happens.  The same thing happens for "place from content center."  Any ideas on what setting/options have been reset?
    Ben
    Inventor 2010
    Vault 2010
    Windows XP Professional x64
    Please use plain text.
    Valued Contributor
    brmanders
    Re: Vault Add-in Grayed out
    06-15-2010 06:22 AM in reply to: brmanders
    It shouldn't be a issue with Vault itself as the Vault tab in AutoCAD works perfectly.
    Employee
    06-16-2010 10:31 AM in reply to: brmanders
    Hello. Please go back into your addin manager and right-click on the white space. Select the option to 'Show Hidden Addins". You will see the "EDM Addin" populate the list.
    Please load that addin and you will now see some more buttons (that are missing from your screen capture). Log in while a Vault ipj is active and all your commands should be available again.
    Adam
    Adam Luttenbacher
    Sr User Experience Designer
    Autodesk, Inc.
    Valued Contributor
    brmanders
    06-16-2010 10:38 AM in reply to: luttena
    It worked, thank you very much!
