• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    VBA script for editing title block in IDW files
    446 Views, 1 Replies
    05-03-2012 05:15 AM
    I've been looking for a while and managed to find 2 VBA scripts for replacing values in a title block. However one errors out on the line that is supposed to do the replacing and the other works off an ID number which isn't consistent.
    I'm a proficient scripter but not in this language, so I have a general idea of how these scripts are working but not the intricacies of them. Which Is exactly what I think is needed to get either of them working.
    Function Test_UpdateTitleBlock()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oTitleBlock As TitleBlock
    Dim oTextBox As TextBox
    Dim oSheet As Sheet
    For Each oSheet In oDoc.Sheets
        Set oTitleBlock = oSheet.TitleBlock
        For Each oTextBox In oTitleBlock.Definition.Sketch.TextBoxes
            If oTextBox.Text = "<FILENAME AND PATH>" Then
                ' Errors here and doesn't replace text
                Call oTitleBlock.SetPromptResultText(oTextBox, "New Value")
        Next
    Next
    End Function
     This throws an error on the line I have marked.
    Function Remove_Filepath()
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    ' Create the new title block defintion.
    Dim oTitleBlockDef As TitleBlockDefinition
    Set oTitleBlockDef = oDrawDoc.ActiveSheet.TitleBlock.Definition
    Dim oSketch As DrawingSketch
    Call oTitleBlockDef.Edit(oSketch)
    oSketch.TextBoxes.Item(20).Text = " "
    Call oTitleBlockDef.ExitEdit
    End Function
    This one works great, except that it does a "dumb" replace because it looks for the Xth textbox and edits that. The problem is in a detail drawing I want to edit textbox 20 but in assembly drawings I don't want to edit any textbox. So if someone could get this to loop through the textboxes and compare the text to what I want to replace that would be awesome.
    Thanks for any help.
    Please use plain text.
    Re: VBA script for editing title block in IDW files
    05-03-2012 10:19 AM in reply to: pball
    Sorry for the double post but it seems either you can't edit posts or at least opening posts.
    It always seems like I manage to get something working after I asking somewhere for help and I always like to share to what I figured out.
    Function Remove_FilePath()
    On Error GoTo ErrMsg
    Dim count As Integer
    count = 1
    While oSketch.TextBoxes.Item(count).Text <> vbNullString
        If oSketch.TextBoxes.Item(count).Text = "<FILENAME AND PATH>" Then
            oSketch.TextBoxes.Item(count).Text = " "
        count = count + 1
    Wend
    ErrMsg:
    End Function
     This function just "removes" the filepath from the title block. It doesn't seem to like substituting in "" but a space works just fine. I take no credit for most of the script, just a bit of credit for hacking it some. It loops through all the textboxes inside of the title block and when it matches the text it replaces it.
