• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    VBA or VB for sculpting overlapping objects in an Assembly??
    149 Views, 1 Replies
    10-19-2012 08:55 AM
    Hi
    I have an assembly with various parts in it.  I am trying to write a routine that will
    1) systematically traverse the assembly and find parts that overlap,
    2) where they overlap perform a sculpt operation on the parts
    Whilst i can do this manually by edit>copy object>sculpt>select surface ...  i don't know how to mimic this programmatically.
     So far i have coded to do it in a very hamfisted way by making a derived part file from the overlapping parts, opening the derived part file and performing the sculpt, replacing the original part in the assembly with its new derived-sculpted part and then continuing to traverse the assembly tree..  - it is super slow and uses lots of file operations.
    Does anyone have any examples of a slick way to do this??
    Thanks in advance
    regards
    Dan
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: VBA or VB for sculpting overlapping objects in an Assembly??
    10-19-2012 09:02 AM in reply to: mitcham_boy
    Hi mitcham_boy,
    You might have better luck searching and asking questions of this type on the Inventor Customization forum:
    http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
