Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
VBA or VB for sculpting overlappin g objects in an Assembly??
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
I have an assembly with various parts in it. I am trying to write a routine that will
1) systematically traverse the assembly and find parts that overlap,
2) where they overlap perform a sculpt operation on the parts
Whilst i can do this manually by edit>copy object>sculpt>select surface ... i don't know how to mimic this programmatically.
So far i have coded to do it in a very hamfisted way by making a derived part file from the overlapping parts, opening the derived part file and performing the sculpt, replacing the original part in the assembly with its new derived-sculpted part and then continuing to traverse the assembly tree.. - it is super slow and uses lots of file operations.
Does anyone have any examples of a slick way to do this??
Thanks in advance
regards
Dan
Re: VBA or VB for sculpting overlappin g objects in an Assembly??
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi mitcham_boy,
You might have better luck searching and asking questions of this type on the Inventor Customization forum:
http://forums.autodesk.com/t5/Autodesk-Inventor-Cu
I hope this helps.
Curtis
