• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Accepted Solution
    VBA error in Inventor 2012 after MS Office 2007 updates august 2012
    835 Views, 6 Replies
    08-16-2012 02:07 AM
    Hi!
    My VBA macro buttons have stopped working today. They worked fine yesterday, before MS sent me a busload of updates (14 to be exact)- among them SP3 for Office 2007.
    When I press any of my buttons nothing happens, but if I open VBA editor and try Debug - Compile, I get "Compile error: Automation error" on every instance referring to any form of Inventor "Document" like "DrawingDocument", "PartDocument" etc.
    Anyone else seen this?
    My system is a Win 7 Ultimate 64-bit, MS Office 2007, Inventor 2012
    Appreciate any feedback!!
    Best regards
    Ivar B Mo
    Fimtech AS
    Norway
    Please use plain text.
    Member
    Re: VBA error in Inventor 2012 after MS Office 2007 updates august 2012
    08-22-2012 05:46 AM in reply to: ivar.mo
    Same problem here:
    AutoCad 2012, office 2007, Windows 7 64 bit Enterprise
    problem after windows updates
    Compile error
    Active Contributor
    08-23-2012 01:15 AM in reply to: ivar.mo
    I solved my issue by following the advice found here:
    http://stackoverflow.com/questions/11971358/excel-vba-automation-errors-due-to-office-service-pack-3...
    For Windows 7 - remember to run cmd.exe "as administrator", and then:
    for 32bit Windows systems:
    regsvr32 -u c:\windows\system32\mscomctl.ocx
    regsvr32 c:\windows\system32\mscomctl.ocx
    for 64bit Windows systems:
    regsvr32 -u c:\windows\syswow64\mscomctl.ocx
    regsvr32 c:\windows\syswow64\mscomctl.ocx
    Fixed my problems! :-)
    Member
    08-23-2012 01:30 AM in reply to: ivar.mo
    I solved it one workstation uninstall en reinstalled Office 2007.
    I will try this ouhter solution on the outher workstations and let you know.
    Member
    08-23-2012 01:46 AM in reply to: mvdijck
    Worked for me :smileyhappy:
    thanx Bether than reinstall office!
    Member
    08-23-2012 04:40 AM in reply to: mvdijck
    Installing office only works temporary After the updates the problem returns.
    Valued Contributor
    01-10-2013 02:25 AM in reply to: ivar.mo
    Second time in two weeks I had to apply this work-around of de-registering and re-registering the OCX's... Those stupid Office-updates...:smileyfrustrated:
    Made a batch-file with the given DOS-commands so I don't have to type the commands in the DOS-prompt everytime MS Office comes with updates...
    Product Design Suite 2012
    Inventor 2012 SP2, Vault 2012
    HP Workstation Z220
    Intel Xeon 3.4GHz
    16GB RAM
    Nvidia Quadro 4000
    Windows 7 Professional (64bit)
