• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Accepted Solution
    Using excel spreadsheet in Design accelerator
    136 Views, 3 Replies
    11-15-2012 04:16 PM
    I am working on a gearbox design that requires multiple iterations on the shaft dimensins and other parts, so linking  the dimiensinos to a spreadsheet would make this easier. However, I'm using the design accelerator for the shaft and other components and I cannot find any information on how to connect the dimensions I enter in that design accelerator to a speadsheet.
    I know how to link to a spreadsheet for a regular component, but haven't used that much.
    Is what I'm trying to do at all possible?
    Thanks for your time.
    Marvin
    Please use plain text.
    Member
    Re: Using excel spreadsheet in Design accelerator
    11-15-2012 08:29 PM in reply to: marvinm
    Hello again,
    after looking into it some more I managed to put in parameters into the design accelerator dimension boxes. However, I cannot access the linked parameters from there. It works fine with a regular sketch, but the accelerator only lists user and model parameters.
    Does anyone know how I can change that?
    Thanks again,
    Marvin
    Member
    11-17-2012 03:13 PM in reply to: marvinm
    In case someone runs into the same problem sometime, here is the solution to my problem (got help from someone else).
    Autodesk seems to have forgotten to integrate the ability to use linked variables in the design accelerator. I got around this by creating a user variable and setting it to be equal to the corresponding linked variable.
    Thanks.
    Marvin
    New Member
    04-29-2013 06:07 AM in reply to: marvinm
    Hello Marvin
    I have the same problem.
    I did not succeded.
    There is a catch?
    Thank you
    Radu
