• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Using View Reps for Detail Views in .idw's, some parts are still visible...
    158 Views, 3 Replies
    10-23-2012 11:07 AM
    I've had this issue now for quite a while.  Seems to only happen with wires that are made in the Cable & Harness module.  And the odd part is that not all wires do this and not all View Rep/Detail views do this.
    Regardless of wether I have a wire visible or not in a locked View Rep it still shows up in the Detail View on the .idw.  And yes, I have the 'associative' check box checked.
    I've unchecked the check box, nothing.  Rechecked the box, nothing.  Updated the views individually, nothing.
    This is ridiculous.  Any help or advice would be greatly appreciated it, thanks.
    Please use plain text.
    Employee
    Re: Using View Reps for Detail Views in .idw's, some parts are still visible...
    10-23-2012 06:38 PM in reply to: KF090
    Could you provide the dataset here and send me @ river-yijiang.cai@autodesk.com for further investigation?
    River Cai
    Quality Assurance Team
    Autodesk, Inc.
    Valued Contributor
    10-24-2012 07:45 AM in reply to: Yijiang.Cai
    I'd have to see if I can do that with proprietary designs.  In the event that I can't is there any ideas as to why this could be happening?
    Valued Contributor
    10-24-2012 08:59 AM in reply to: KF090
    I was able to finally get it to work.  Here's how:
    I had to go and Edit View each of the effected Detail Views.  Change the View Rep to the Default view, click OK.  Go back in and click on the View Rep that I need it to be and then the wires disappear.
    Something is definitely wrong there.
