• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Accepted Solution
    Using Tables in Assembly
    157 Views, 6 Replies
    10-03-2012 08:29 AM
    I seem to remember from years ago that tables could be used to insert multiple occurences of a single component into an assembly. Is that true or just a dream on my part? Thanks.
    Please use plain text.
    *Pro
    jletcher
    Re: Using Tables in Assembly
    10-03-2012 08:33 AM in reply to: Oakcutter
    Are you talking iparts?
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    Active Member
    10-03-2012 08:34 AM in reply to: jletcher
    Yessir, B.L. Oats Mingo Mfg. Inc. Phone: 918-272-1151 Direct Line: 918-212-1214 Fax: 918-212-1214 boats@mingomfg.com
    *Pro
    jletcher
    10-03-2012 09:32 AM in reply to: Oakcutter
    Ok so what did you need? :smileyhappy:
    James Letcher
    Active Member
    10-03-2012 09:52 AM in reply to: jletcher
    I have an Inventor assembly that contains an enormous quantity of the same part. Also, there's not much of a pattern so therefore an array does not help much. So I was wondering if I could create a table with x,y,z coordinates of all the insertion points which would drive the insertion process?
    *Pro
    jletcher
    10-03-2012 10:42 AM in reply to: Oakcutter
    Look into work points using excel. This may be a good way. Or look into ilogic to control the work point location. You may also want to look at imates to place them using the work point..
    James Letcher
    Active Member
    10-03-2012 11:02 AM in reply to: jletcher
    Thanks, I just looked briefly into work points and I think thats the answer.
