• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Using Split Command
    54 Views, 1 Replies
    01-09-2013 07:01 AM
    I am wondering how many times you can use split command on one part?
    I have never used split command before.
    if you look at the image below, i would like to split this into 4 pieces, and looking for the quickest and the way that makes the most sense way to do it.
    Also another side question. is there anywhere i can sign up for free webinars that are good to attend on inventor?
    Please use plain text.
    Re: Using Split Command
    01-09-2013 07:04 AM in reply to: rsagan85
    I am not aware of any limitations on number of Split features
    - but I suspect there is an far easier technique in this case.
    (You will want to become familiar with mutli-body solids techniques or Frame Generator).
    http://au.autodesk.com/?nd=classes
