• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Using Inventor DWG instead of IDW
    266 Views, 9 Replies
    03-12-2009 01:03 PM
    The company I just started with started using Inventor a year ago and do all drawings in the Inventor DWG format instead of using the IDW. When they first purchased Inventor the choice was there to use Inventor DWG or Inventor IDW and they chose the DWG format (mainly because they had been using AutCad and were familiar with that file extension. There is no apparent reason at this time to do this but I'm curious as to the shortcomings in the future. Previously, I have always used the IDW format (at other companies) as the choice was not there when I started using Inventor. It appears that the DWG format files are larger on most assemblies but other than that I am looking for reasons for a switch to the IDW format. Since a number of drawing files are already completed in the DWG format I will need some reasons why this direction should be changed to the IDW unless there is absolutely no reason to change. I know you can save an Inventor DWG as an IDW but a message is displayed "The file contains data that cannot be written to the selected file format. Only native Inventor data will be written to this file." and once this is accepted then the Inventor DWG is then saved to the IDW format. As I mentioned, I am looking for some good reasons to switch to the IDW format (if any) or if any others are saving to the DWG format as well. My concern would be that Autdesk would drop the DWG from the Inventor software as it seems to have been added later to satisfy those those use both AutoCad and Inventor in their departments. Just looking for input............
    Please use plain text.
    *Andrew Faix \(Autodesk\)
    Re: Using Inventor DWG instead of IDW
    03-12-2009 03:52 PM in reply to: cames71646
    I'll give you a somewhat-official Autodesk
    response, and sit back and hope some end users back me up :smileyhappy:
    I think you've already discovered the pros and cons
    of each file format yourself.  DWG files are a bit bigger, but can be read
    into AutoCAD without having to do anything special.  If you switch to IDW
    and an AutoCAD user wants to take a look at the file, someone's going to have to
    convert the file to DWG (either an Inventor DWG or a translated AutoCAD
    DWG).  When the DWG True Connect technology was released with Inventor
    2008, we told users that if there's any chance of a down-stream consumer ever
    wanting a DWG version of your drawing file, you should strongly consider using
    DWG as your native drawing format.  From my point of view, there's NO
    compelling reason to go back to IDW unless you're really that hard up for hard
    drive space (and if that's true, then Inventor's drawing file format is far from
    your biggest problem).
    If there's any pros or cons beyond that, we haven't
    done our job.  There should be absolutely no data or visual fidelity loss
    moving between formats.  The DWG file will contain a Layer 0 and a Drawing
    Resource folder for AutoCAD blocks, but that should be the only discernible
    difference.
    You can take this for what its worth: we have no
    plans to retire either one of these formats.  There simply is no business
    case for it.  We invested a LOT of resources to add DWG as a supported
    native format I can't imagine why you think we would choose to drop what is far
    and away the most popular CAD drawing format in the world (is there even a close
    2nd?).
    Hope that helps.  If anyone would care to
    confirm or refute those claims, please do.
    Good Luck!
    -Andrew Faix
    Product Design
    Lead
    Inventor Core Applications
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    The
    **Master
    03-12-2009 04:18 PM in reply to: cames71646
    >>I am looking for some good reasons to switch to the IDW format (if any) or if any others are saving to the >>DWG format as well. My concern would be that Autdesk would drop the DWG from the Inventor software as >>it seems to have been added later to satisfy those those use both AutoCad and Inventor in their >>departments.
    I think file size is really the only CON, the PRO's are the ability for AutoCAD users to access them, the ability to e-mail the out as is with no need to convert, the ability to use the drawing views as blocks in model space, and the ability to use AutoCAD blocks as sketched symbols in Inventor. I really doubt that either the IDW or DWG are going to be discontinued. And you can always batch convert using the Task Scheduler as well.
    Drive space is not the big concern with the larger file size, its more about capacity and performance. I've seen DWGs that are 3X larger than the same IDW. If it's 2500 part assembly drawing with lots of views, including sections, etc. then this "bloat" becomes a real issue as load times get slow. If that's not an issue then the DWG's extra abilities are probably worth it. I'd most likely use IDW's for large assemblies, and DWG for the rest. Personally I see no reason to choose one over the other.
    Distinguished Contributor
    03-12-2009 05:33 PM in reply to: cames71646
    IMHO (and yes it is only an opinion and I know what they say about 'em),
    If anything they should drop IDW. Why actively develop and support two file formats, when one of those works perfectly fine AND makes interoperability painless.
    Kind of comes back to the "We are not planning to retire Mechanical Desktop".
    Ronnie Wilkins, Jr.
    AMS CAD + CAFM Solutions
    Sr. Solutions Developer
    Autodesk Certified Instructor: Inventor
    *Dennis Jeffrey
    03-12-2009 05:48 PM in reply to: cames71646
    The IDW file merely contains links back to the original
    ipt/iam files and loayout views, and is inherently smaller than the
    Inventor DWG file which includes model "blocks" and layouts ( paperspace). The
    AutoCAD  ( Save Copy As AutoCAD DWG) dwg format only contains model space
    views, and are lighter weight. I'm personally seeing more users move to the DWF
    format for even more universal viewing compatibility. I have to agree with
    Andrew, that it's more of a case of "to each his own...."
    Dennis Jeffrey, Autodesk Inventor Certified
    Expert
    Autodesk Manufacturing Implementation Certified
    Expert.
    Instructor/Author/Sr. App Engr.
    AIP 2008 SP3, AIP 2009-SP1
    PcCillin AV
    HP zv5000  AMD64 2GB - Geforce Go 440, Driver: .8185
    XP
    Pro SP3, Windows XP Silver Theme
    href="http://teknigroup.com">http://teknigroup.com
    **Master
    03-12-2009 08:06 PM in reply to: cames71646
    2nd?).
    Close 2nd = DXF
    03-13-2009 08:28 AM in reply to: cames71646
    It's a LOT more expensive to maintain an entire
    software application than an additional drawing format.  I'm pretty low on
    the totem pole, but from my perspective, IDW isn't going anywhere.
    Cheers,
    -Andrew
    IMHO
    (and yes it is only an opinion and I know what they say about 'em), If
    painless. Kind of comes back to the "We are not planning to retire Mechanical
    Desktop".
    New Member
    09-19-2012 07:27 AM in reply to: cames71646
    When I save copy as DWG from  IDW, what I got is a ZIP file inseated of DWG, Why????,
    Distinguished Mentor
    09-19-2012 08:39 AM in reply to: swalke3
    If you are saving as an Autocad dwg, check the options and make sure pack and go is not checked.
    John Retzlaff
    09-19-2012 09:11 AM in reply to: *Andrew Faix \(Autodesk\)
    " DWG files are a bit bigger"
    Maybe if you do small assemblies and parts.
    Our company can't use the dwg format because the file size goes to 40-50 mb (inventor dwg) instead of 1-2mb (if I save as dwg from idw)
    Most of our models are 1-5k parts with alow of duct and pipe, I'd hope to see autodesk research making the inventor dwg file size smaller.
    A jump of 20 times the file size is more than just a bit in my opinion.
