• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Orbitron
    Using Created Dimensioning Styles
    143 Views, 6 Replies
    02-27-2012 06:56 AM
    I've read the Wiki Help and did a search for related topics, but none answer my question.
    I needed to create new dimensioning styles - that I can do.  However, there doesn't seem to be a way to apply them to a current drawing.  In the Annotation section under Format there are no "styles" listed  - not even the default.
    So, how is one able to populate the list so one may choose a specific style or another?  Or, is there somewhere else I should be looking?
    BTW...AutoCAD Inventor 2012
    Please use plain text.
    cbenner
    Re: Using Created Dimensioning Styles
    02-27-2012 06:59 AM in reply to: Orbitron
    In the Styles Editor, look for "Object Defaults".  Creating a new Dim style, only makes it available.  In Object Defaults, you can actually assign that style to the various dimension types (liner, radial etc).  Once assigned there, you should be able to use them.
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Orbitron
    02-27-2012 07:13 AM in reply to: cbenner
    Thanks for the reply.  I found the "Object Defaults", but I see nothing there that allows me to assign anything.  I can filter the list - nothing more.
    cbenner
    02-27-2012 07:18 AM in reply to: Orbitron
    Is there a style under the Object Defaults.. .or more than one?  It should look like this:
    First column is the Object type, second is the style you want to assign to that object. On the left under Object Defaults, you can create multiple styles, for different types of documents.... if you choose.
    ChrisB
    Active Contributor
    02-27-2012 07:45 AM in reply to: Orbitron
    On your standard, make sure it is checked under available styles.
    Donald L.
    Inventor Product Design Suite Premium 2013 SP1.1
    Windows 7 Professional - 64 bit
    HP h8-1380t - i7-3820 @ 3.6 GHz
    10 Gb
    AMD Radeon HD7950 3Gb
    Orbitron
    02-27-2012 08:59 AM in reply to: cbenner
    Thank you gentlemen!  It still took some playing around with, but I believe I understand the relationships and sequence of events much better.
    Active Contributor
    02-27-2012 09:05 AM in reply to: Orbitron
    If you want to make them globally available, don't forget to save them to your style library.
    Donald L.
    10 Gb
