• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    jstorella
    Accepted Solution
    User work plane, axis and points bug
    211 Views, 7 Replies
    12-17-2012 11:01 AM
    Currently using 2012 and I had the same problem in 2010.
    When I turn visibility off and on in an assembly, all previously constructed user planes, axis and points become visible.
    Is there a fix available to download?
    Jerry
    Please use plain text.
    *Expert Elite*
    cbenner
    Re: User work plane, axis and points bug
    12-17-2012 11:30 AM in reply to: jstorella
    Are you talking about using Object Visibility?  If you toggle work planes on, all work planes which are set in their original part or assembly as visible, will become visible.  All that are set to invisible in the original part or assembly will remain invisible.  Object visibility just tells the parts or assemblie to display these items as they are set in the original part or assembly.
    Ex.  Assembly "A" has parts 1,2, & 3 in it.  In part 1, all origin planes had the visibility manually set to off.  2 & 3 did not.  At the Assembly "A" level the user sets Object Visibility of origin planes to Visible... he will only see the origin planes for parts 2 & 3.
    Was this what you were asking?
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Active Contributor
    jstorella
    12-17-2012 11:55 AM in reply to: cbenner
    No, I know how to use object visibility and turn origin and user planes, axis and points visibility on and off in the browser.
    My problem is, when in a high iam and I need to make a lower iam invisible to perform a function, when I inturn make the lower iam visible again, all the user created planes, axis and points then become visible even though I have them invisible through the browser. To fix this I can find each plane, axis or point and turn them off in the browser or go to View, Object Visibility and turn them all off there, but that also turns off visbilty of any user plans I am currently using or I can leave all visible and work in that environment. This was a problem in 2010 as well as 2012 that I am currently using.
    J.
    Distinguished Contributor
    BLHDrafting
    12-17-2012 04:49 PM in reply to: jstorella
    It's annoying and I have not found a fix yet.
    What I do is use the keyboard commands to turn all on/off :-
    CTRL + ] = toggle origin places
    CTRL + / = toggle origin axis on/off
    CTRL + . = toggle origin centre point on/off
    Substitute ALT for CTRL to toggle user planex/axis/points.
    Not perfect but quick and saves manually find ALL of those offending planes/axis/points and turning them off only to see them on again later!
    Brendan Henderson
    Web www.blh.com.au
    Twitter @BLHDrafting
    Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
    ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD
    Inv R2013 PDS SP1.1 Update 2, Vault 2013 Workgroup Update 1
    Distinguished Mentor
    -niels-
    12-17-2012 11:17 PM in reply to: BLHDrafting
    I think this also has something to do with sub-assemblies reverting to their "master" design view when turned invisible.
    (which is a bit annoying in my opinion)
    You can "fix" it by right-clicking the sub-assy, selecting "representation" and choosing the "default" or other relevant design view from the dropdown list.
    You could also check the mark for "associative" but that'll give warnings when you try to make the sub-assy invisible again...
    Using IV2013 Pro SP1.1, Win7-64bit
    Active Contributor
    jstorella
    12-18-2012 05:52 AM in reply to: -niels-
    Understood.....
    ampster
    12-18-2012 06:20 AM in reply to: jstorella
    I don't experience this due to the habit of turning off work features before closing a part file.
    But it sounds like I'm the minority when it comes to this.
    Active Contributor
    jstorella
    12-18-2012 06:50 AM in reply to: ampster
    I follow the same practice of turning origin and user planes axis and points off when I thru. Read my second description of problem.
    J.
