• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Use ilogic/VBA to check a list of drawings into Vault
    238 Views, 0 Replies
    11-23-2012 12:31 AM
    Hi there,
    I have a large set of drawings which are all very similar as they were created from the same iassembly factory.  I have been using ilogic to go through the set of drawings and make changes.  In the example below I have used ilogic to delete the current parts list and replace it with a corrected version:
    DimiAsInteger
    DimoMemberFileAsString
    'Enter the last four digits of iAssembly members for which drawings will be generated
    Fori=4982To5018
    'Get the full file name of iAssembly member
    oMemberFile="C:\ARTICULATE\09\090\09090GT0000023\09090G0010"&CStr(i)
    ThisDoc.Launch(oMemberFile&".idw")
    DimoDrawingDocAsDrawingDocument
    oDrawingDoc=ThisApplication.ActiveDocument
    DimoSheetAsSheet
    oSheet=oDrawingDoc.ActiveSheet
    'Delete the current parts list
    DimoPartsListAsPartsList
    oPartsList=oDrawingDoc.ActiveSheet.PartsLists.Item(1)
    oPartsList.Delete
    ' Set a reference to the first drawing view on
    ' the sheet. This assumes the first drawing
    ' view on the sheet is not a draft view.
    DimoDrawingViewAsDrawingView
    oDrawingView=oSheet.DrawingViews(1)
    ' Set a reference to the sheet's border
    DimoBorderAsBorder
    oBorder=oSheet.Border
    DimoPlacementPointAsPoint2d
    xrev=oBorder.RangeBox.MaxPoint.X
    yrev=oBorder.RangeBox.MaxPoint.Y
    oPlacementPoint=ThisApplication.TransientGeometry.CreatePoint2d(xrev, yrev)
    ' Create the parts list.
    DimoPartsList1AsPartsList
    oPartsList1=oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
    oPartsLis1t=oDrawingDoc.ActiveSheet.PartsLists.Item(1)
    oPartsList1.Sort("ITEM", 1)
    'Save copy as one new idw using the member name
    oDrawingDoc.Save
    oDrawingDoc.Close
    Next
    I want to add a line of code so that once the document has been saved, it will then be checked into Vault.  Is this possible using ilogic or would I have to use the VBA?
    Wayne
    Wayne Helley
    Inventor 2013 Certified Professional
    Autodesk Inventor Professional 2011
    Windows 7 Enterprise, 64-bit
    Please use plain text.
