• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Use filename as parameter
    166 Views, 11 Replies
    11-08-2006 03:14 PM
    Is there a way to use the filename to drive the parameters of the file?
    Example: I have a cube that is called 4x4x4.ipt its dimensions d0,d1,d2 are 4,4,4 respectively. I want to rename it to 4x4x6.ipt and have the dimensions d0,d1,d2 resize to 4,4,6.
    Please use plain text.
    Distinguished Contributor
    Re: Use filename as parameter
    11-08-2006 06:41 PM in reply to: EmpireBuff
    Option 1: Through VB code read the filename and parse it and then set it to the parameters d0,d1,d2 and update. autodesk.inventor.customization group could provide more help here.
    Option 2: You might be knowing this already you can create an iPart with d0,d1,d2 as columns and then create keys for them and then see if that works out. You could add rows for as many variations as possible. This does create files though.
    shekar
    *Teun Ham \(IV10 SP3\)
    11-09-2006 12:28 AM in reply to: EmpireBuff
    Free of charge ;-)
    T. Ham
    Mechanical Engineer
    CDS Engineering BV
    HP xw4300 Workstation
    Dual Pentium XEON 3.6 Ghz
    4 GB SDRAM
    NVIDIA QUADRO FX 3450/4000 SDI (Driver = 8.4.2.6)
    250 GB SEAGATE SATA Hard Disc
    3Com Gigabit NIC
    Windows XP Professional SP2
    Autodesk Inventor Series 10 SP3a
    11-09-2006 12:33 AM in reply to: EmpireBuff
    option 3 get a copy of yippee pro.
    use the parameters to drive the filename
    11-09-2006 01:01 AM in reply to: EmpireBuff
    The only problem...he wants it the other-way-around :-)
    T. Ham
    Mechanical Engineer
    CDS Engineering BV
    4 GB SDRAM
    3Com Gigabit NIC
    11-09-2006 01:23 AM in reply to: EmpireBuff
    some say tomato, some say tomato, wait that doesnt work here...
    i really should think about learning some code, nice work
    11-09-2006 02:19 AM in reply to: EmpireBuff
    For those of you who are curious how Teun did it he used Option 1. When you open the IPT file attached by Teun go to Tools, Macro, Visual Basic Editor to see the script that will be run when the file is opened. Nice job Teun. Thanks.
    shekar
    11-09-2006 02:49 AM in reply to: EmpireBuff
    One remark: the macro is embedded in the IPT. This can cause problems when
    you have a lot of IPTs open at the same time (it's a VBA limitation, so you
    can blame Microsoft for it)
    An Add-in would solve that problem, but my example is just to show that it
    can be done!
    Cheers,
    T. Ham
    Mechanical Engineer
    CDS Engineering BV
    4 GB SDRAM
    3Com Gigabit NIC
    New Member
    11-09-2006 06:30 AM in reply to: EmpireBuff
    You have all been very helpful, especially you Teun, I was trying to do this for a while now and only found out about this discussion group yesterday. My first experience has been very good !!!!
    Cheers !!!
    11-09-2006 07:33 AM in reply to: EmpireBuff
    No problem!
    T. Ham
    Mechanical Engineer
    CDS Engineering BV
    4 GB SDRAM
    3Com Gigabit NIC
