• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Urgen help with a part!! Please!!
    337 Views, 14 Replies
    02-12-2013 04:22 AM
    I need to make the surfaces on the back of this case smoother. Please see attached picture with arrows pointing at the surfaces, that pretty much need to disapear and make a smooth transition.
    Please let me know if you can help.
    Nuno Felix
    Please use plain text.
    *Pro
    Re: Urgen help with a part!! Please!!
    02-12-2013 04:46 AM in reply to: NunoFelix
    I would try Delete Face with Heal.  But if you post your file (and tell us what version of Inventor you're using), I'll bet someone here can help you figure it out.
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
    Active Contributor
    02-12-2013 04:54 AM in reply to: sbixler
    I can't seem to be able to upload the file. Thank You, Nuno Felix Machine Shop Technician
    Nuno Felix
    *Pro
    02-12-2013 04:55 AM in reply to: NunoFelix
    Open the file, drag the End of Part marker to the top of the feature tree (which hides all features and makes the file much smaller), save, then attach.
    Sam B
    02-12-2013 06:44 AM in reply to: NunoFelix
    Anyone who is making something more complex than a box or cylinder should watch this video.
    http://au.autodesk.com/?nd=class&session_id=10379
    Active Contributor
    02-12-2013 10:19 AM in reply to: NunoFelix
    here is a link to the file
    http://grabcad.com/questions/urgent-autodesk-inventor-help-please
    Nuno Felix
    02-12-2013 10:56 AM in reply to: NunoFelix
    I recommend starting the part over from scratch following the guidlines from the link posted above.
    Your file is more complex and larger file size than needed to create the geometry.
    Rebuild All causes many errors and I would use far far fewer (if any) adaptive sketches as they aren't needed.
    Active Contributor
    02-12-2013 12:05 PM in reply to: JDMather
    I would, but i have till tomorrow to finish it and i wont have time to start over...
    Nuno Felix
    02-12-2013 12:24 PM in reply to: NunoFelix
    That is what my students always tell me.
    Then next day (due date) they tell me that they started over at midnight and all went much faster, smoother, better than trying to fight a flawed technique that was flawed from the very first sketch.
    Active Contributor
    02-12-2013 12:51 PM in reply to: JDMather
    LOL, trust me, that is not the case... im not a student either.
    Nuno Felix
