Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Update a Custom Frame Generator Shape
- Highlight
- Email to a Friend
Inventor 2013
Windows 7 Professional 64-bit SP1
HP EliteBook 8470w
Processor: Intel(R) Core(TM) i7-3610QM CPU @ 2.30GHz
Memory: 16 GB
AMD FirePro M2000
3D Connexion SpacePilot
Re: Update a Custom Frame Generator Shape
- Highlight
- Email to a Friend
I've found to just re-publish the corrected FG item.
IV2014.1 PDSU / Sim Mech 2014 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 314.07
SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
- Highlight
- Email to a Friend
Have you demoted the parts to an assembly, or are they still in the original FG assembly? Do you need it to show on the drawing for reference? if not right-click on the part and suppress it. You can also manually open the parts list, and hide the part in it by turning that line's visibility off. I have had problems where an FG part will not delete when I wanted to delete it. Fixed that by replacing it with any non-FG part then deleting. You should be able to go into the BOM and change the part from Normal to Phantom.
Lee C. Moore, Inc.
www.lcm-wci.com
Inventor 2011
Intel Dual Xeon E31225 @ 3.1 GHz CPU
16 GB RAM
NVIDIA Quadro 600 GPU
Windows 7 - 64 Bit
- Highlight
- Email to a Friend
Actually, I should have been more specific (the story of my life). I want to set the part so each time it is used in a frame generator assembly it won't show in the parts list. Right now I go in and turn off these parts manually but since I have to do it each time I wanted to have it default so it won't show.
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
- Highlight
- Email to a Friend
In 2012 this didn't work for me so I never tried it in 2013. Now it works so I guess its fixed. Thanks again.
Inventor 2013
HP EliteBook 8470w
Memory: 16 GB
AMD FirePro M2000
