• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Unwanted detail in drawings.
    144 Views, 4 Replies
    01-17-2013 03:58 AM
    In the idw of my assembly hidden detail is turned off although there is still sub assemblies shown through the main container. Also when there is a section these sub assemblies are show with dotted lines an overlap compionets they are behind.
    My questions are
    1. Why are they showing through components they are behind.
    2. Why are the lines dashed
    See attached image
    Please help
    Please use plain text.
    *Pro
    sbixler
    Re: Unwanted detail in drawings.
    01-17-2013 04:37 AM in reply to: DLIDHYDRA
    Those appear to be hidden lines-- are you sure that those views have hidden lines turned off?  Otherwise, it's possible that those components are set to Reference in the assembly, which means that they will not appear in parts lists, and will, by default, show as phantom in the drawing.
    What version of Inventor are you using?
    Sam B
    Inventor 2012 Certified Professional
    Please click "Accept as Solution" if this response answers your question.
    Inventor Professional 2013 SP1.1 Update 1
    Windows XP Pro 32-bit, SP3
    HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
    SpaceExplorer/SpaceNavigator NB, driver 3.7.18
    still waiting for a foreshortened radius dimensioning tool in Drawing Manager
    Member
    01-17-2013 05:19 AM in reply to: sbixler
    Yes they definatley have hidden lines turned off otherwise all the componts would show wouldnt they? As it is only 6 sub assemblies this is happening with.
    What do you mean by set to reference in the assembly?
    Inventor 2012
    *Pro
    sbixler
    01-17-2013 05:40 AM in reply to: DLIDHYDRA
    In the assembly, right click on the component and choose iProperties.  On the Occurence tab, see if Reference is checked.
    Sam B
    Member
    01-17-2013 08:06 AM in reply to: sbixler
    Reference was checked now changed it to default now and is perfect
    Thanks would have never got that.
    David
