• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Unolding a fold?
    145 Views, 5 Replies
    01-29-2010 11:36 AM
    All I'm doing is scetching a rectangle, creating a face, scetching a line and creating a fold. Why won't it unfold?
    V11
    Please use plain text.
    Re: Unolding a fold?
    01-29-2010 11:46 AM in reply to: Deadhorse
    Select a face first.
    You are doing too much work though. A countoured flange would be much easier to get the same results.
    Valued Mentor
    01-29-2010 11:50 AM in reply to: Deadhorse
    You could just sketch the open profile, then do a contour flange, I'm sure that would work in v11.
    Alternatively,
    To fix your model (this worked for me in 2010) follow these steps
    1. Delete the flat pattern
    2. Move the "End of Folded" marker to just below "Fold 1"
    3. Highlight the large flat surface
    4. Click flat pattern (it should flatten)
    5. Click back to the folded part
    6. Move the "End of Folded" marker to just below "Fold 2"
    7. Then click flat pattern again
    That is what worked for me, I know they have overhauled the sheet metal module since v11 so it may not work for you.
    Ryan
    Ryan
    Inventor Version:
    Build: 535, Release: 2011 SSR - Date: Fri 08/20/2010
    64-Bit Edition - 8192.00 GB
    Dell Precision T3500
    Intel(R) Xeon(R) CPU W3540 @ 2.93GHz (8 CPUs), ~2.9GHz
    6.00 GB RAM
    Windows Vista™ Ultimate (6.0, Build 6002) Service Pack 2
    NVIDIA Quadro FX 1800 8.17.0012.5849
    Valued Contributor
    01-29-2010 11:52 AM in reply to: Deadhorse
    I tried a contured flange and when I tried to flat patter I got, errors ocurred during update. Could not build asmflatpattern. No base plane found.
    What did you mean by select the face first?
    Valued Contributor
    01-29-2010 11:57 AM in reply to: Deadhorse
    I got it, thanks. But why with this feature/part do you have to select the face first?
    Valued Mentor
    01-29-2010 12:00 PM in reply to: Deadhorse
    Inventor needs a fixed face as a base point for all the flattening and folding, sometimes, when it isn't and obvious face then you have to tell inventor which face is the base.
    If that makes any sense.
    I guess it could just ask you to pick a face every time like some other programs...
    Ryan
    Ryan
    Inventor Version:
    6.00 GB RAM
