• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Valued Contributor
    luiww
    Accepted Solution
    Unlink line
    449 Views, 5 Replies
    09-03-2010 06:05 AM
    When I start to constrain the sketch using vertical constraint, I was surprised to see that the end points get aligned but the line also got move out of position.  I may have accidentally set the Tools option but unable to figure out where the error is.
    ****Sage
    Re: Unlink line
    09-03-2010 06:11 AM in reply to: luiww
    You are missing other constraints.
    Right click an select Show All Constraints.
    Right click and Show Degrees of Freedom.
    I recommend beginners sketch one line, circle, rectangle or polygon and dimension/constrain immediately before continuing.
    http://home.pct.edu/~jmather/skillsusa%20university.pdf
    Autodesk Inventor Certified Professional
    Inventor Professional 2012 Edu 32-bit
    Still waiting for -Draft option on any Rib feature. -Properties Painter.
    Still wondering why Edit Form is above Edit Feature on RMB?
    Valued Contributor
    luiww
    Re: Unlink line
    09-03-2010 06:14 AM in reply to: JDMather
    Here is what I got after showing all constraints and dof.  Still not knowing where I have gone wrong.
    ****Sage
    Re: Unlink line
    09-03-2010 06:32 AM in reply to: luiww
    Might have been more instructive to attach the file, but -
    looks like you are missing a whole bunch of coincident constraints.
    Did you fool with Constraint Persistence or Constraint Options?
    It looks like you have Constraint Persistence on now, but could you have turned it off earlier by mistake?
    *Pro
    Re: Unlink line
    09-03-2010 07:44 AM in reply to: JDMather
    You can have both buttons active, but if Constraint options are turned off, then you have overriden the constraints. RMB in the graphics area, and select Constraint options. Turn them all ON.  This link should help explain constraint settings:
    Sketch persistence
    http://teknigroup.com/courseware/2010/Module00/sk1/Videos/sk1-100/sk1-100.html
    506iBE1D9A398981B273
    ____________________________________________________________
    Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
    Autodesk Manufacturing Implementation Certified Expert
    Autodesk Silver Manufacturing Partner
    Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
    XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
    Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
    Valued Contributor
    luiww
    Re: Unlink line
    09-03-2010 09:25 PM in reply to: Dennis_Jeffrey
    Hi Dennis, that is exactly what I miss out and need and am glad to be able to get help so soon from here.  This is definitely accepted as solution and I like to thank the helper.
    However, if I click the accept as solution, I will not be able to show any appreciation.  I wonder if there is any opportunity for one to pen his words of kindness or upload the solution after accepting the solution.
