Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Unfold problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Windows XP sp3
Inventor 2010 sp3
I have this piece in the sheet metal environment. It should be an even .375". I cannot get it to unfold. I have tried remodeling it with a straight path and an elliptical curve with the same result.
Re: Unfold problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Your part is not modeled correctly for a sheet metal part.
Autodesk Inventor Certified Professional
Inventor Professional 2012 Edu 32-bit
Still waiting for -Draft option on any Rib feature. -Properties Painter.
Re: Unfold problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Um...could you be more specific? I thought the restriction was an even thickness that can be unfolded. Id the loft what is causing the issue?
Re: Unfold problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
grim2020 wrote:I thought the restriction was an even thickness that can be unfolded.
Are you willing to start over from scratch?
Re: Unfold problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I can visualize some of the steps, but not quite all. Fire away...
Re: Unfold problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
grim2020 wrote:Fire away...
I am curious how this part fits with the mating parts since Loft actually results in some rather undefined edges. Before I spend time presenting a solution I would like to confirm that it is the correct solution. Can you attach the mating parts here or supply more information on the assembly design intent.
Re: Unfold problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Good morning,
Sorry for the delay. The part was sent to me from a client. It is a portion of a water gateway that starts as an oblong in the horizontal and ends in 90 degrees offset to one side as a circle in the vertical. I do not have the whole model, just this piece, but I can request it for tomorrow as the company isn't working today. I would greatly benefit from your wisdom as to how to approach breaking the parent object down into unfoldable plates.
Thank you JD.
Re: Unfold problem.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Grim,
Here is some ideas for you. The model is not exactly the same as yours but. Id would help to see the picture where the part goes.
Igor.
