Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Turning lots of features on and off in ilogic
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is there a better way to turn alot of features on and off than haveing it turn them on and off for each case? I have put the code but this takes a while to process and I was wondering if there was a faster way to make this happen than markign each one for being turned on or turned off. I am using 2011 and this is ilogic for a multi body solid that will be made into an assembly later.
'EFFLUENT RULES FOR TURNING FEATURES ON AND OFF
If EffluentType="Drop Pipe" Then
Feature.IsActive("DropPipeFlange")=True
Feature.IsActive("DropPipeEndRim")=True
Feature.IsActive("DropPipeExtrusion")=True
Feature.IsActive("DropPipeCut")=True
Feature.IsActive("DropPipeChannelEnd")=True
Feature.IsActive("EffluentChannelRim")=False
Feature.IsActive("PipedEffluentTrim")=False
Feature.IsActive("PipedEffluentFill")=False
Feature.IsActive("PipedEffluentPipe")=False
Feature.IsActive("PipedEffluentFlange")=False
Feature.IsActive("PipedEffluentCut")=False
Drop = iFeature.FindRow("DropPipeFlange", "PipeDiameter", "=", EffluentPipeDiameter)'Change iFeature Flange size
iFeature.ChangeRow("DropPipeFlange", Drop)
ElseIf EffluentType="Channel" Then
Feature.IsActive("DropPipeFlange")=False
Feature.IsActive("DropPipeExtrusion")=False
Feature.IsActive("DropPipeCut")=False
Feature.IsActive("DropPipeChannelEnd")=False
Feature.IsActive("EffluentChannelRim")=True
Feature.IsActive("DropPipeEndRim")=False
ElseIf EffluentType="Pipe" Then
Feature.IsActive("PipedEffluentTrim")=True
Feature.IsActive("PipedEffluentFill")=True
Feature.IsActive("PipedEffluentPipe")=True
Feature.IsActive("PipedEffluentFlange")=True
Feature.IsActive("PipedEffluentCut")=True
Piped = iFeature.FindRow("PipedEffluentFlange", "PipeDiameter", "=", EffluentPipeDiameter)'Change iFeature Flange size
iFeature.ChangeRow("PipedEffluentFlange", Piped)
End If
Re: Turning lots of features on and off in ilogic
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Every call to Feature.IsActive will do an Update, so it can be slow. As a workaround, you can have the rule set the end-of-part marker to the top of the model tree. The part will be temporarily empty, and updates will be fast. Add this to the top of your rule:
Dim partDoc as PartDocument = ThisDoc.Document partDoc.ComponentDefinition.SetEndOfPartToTopOrBottom(True)' Set to top
And add this at the bottom:
partDoc.ComponentDefinition.SetEndOfPartToTopOrBottom(False) ' Set to bottom
If you need more control over the end-of-part, there is a way to move it before or after a particular feature.
Mike Deck
Software Developer
DLS - Mechanical Design
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
the colors of all that text is brown (like its incorrect maybe) Should it be purple like the rest of the commands?
ThisDoc.Document is purple and Dim is red I just wanted to make sure this is correct the rule closes and like there is no syntax error but I wanted to make sure there was no error.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Those colors sound OK. Most of that code is Inventor API code (not iLogic functions), so iLogic doesn't show it in purple. Dim shows up in red because it is a Visual Basic keyword.
Mike Deck
Software Developer
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks that worked I think.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think moving the End Of Part could be useful for a rule I am setting up. How do you go about writing a command to specify where to move the EOP to?
Sorry for jumping into an old thread.
Inventor 2011 SP2, Vault Professional 2011
Dell T3400 Core2 Quad 2.4GHz. 8.0GB RAM
Nvidia Quadro FX1700 (x2)
