• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    New Member
    Tube and Pipe
    87 Views, 1 Replies
    11-08-2012 09:13 AM
    After creating the route, I can not get it to populate with the actual pipe. How do you get the route to populate with a 1/2" tube or pipe?
    Please use plain text.
    *Expert Elite*
    cbenner
    Re: Tube and Pipe
    11-08-2012 11:20 AM in reply to: mattb
    Need a lot more information.  What version are you using?  What tube or pipe style are you trying to populate from?  Do you have access to Content Center?  What exactly are you seeing when you attempt to populate?  What is your general workflow?
    Gee... is that enough questions?
    AutoCAD 2013, IV 2013 Pro Tube and Pipe - Frame Generator, Vault Pro 2013 Win 7 x64, Dell precision PWS690, GeForce GTX580
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
