• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Rherman
    Accepted Solution
    Trying to place cross dowels into multipule holes easly
    144 Views, 2 Replies
    05-03-2012 08:18 AM
    I am trying to place a cross dowel into multiple holes. Is there an easy way to automate this? Currently I am placing a cross dowel component and then constraining it to the hole one at a time. Quite a long process to place hundreds of them.
    Thanks for the help!
    Please use plain text.
    Valued Mentor
    japike
    Re: Trying to place cross dowels into multipule holes easly
    05-03-2012 08:43 AM in reply to: Rherman
    Check out imates or Pattern Component using Feature Pattern Select.
    Peace,
    Jeff
    Inventor 2013
    *Expert Elite*
    05-03-2012 09:23 AM in reply to: japike
    Or kwiksert (great addin) Not free but easily worth every penny if you do this quite often.
    You could also try the "assemble" workflow/dialog instead of the regular constraint dialog.
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
