• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Re: Troubles Creating a New Family in Content Center
    02-06-2013 10:24 AM in reply to: cwhetten
    Thanks.  This looks like it may be my ticket.  I am going to work with this for a while and let you know it goes.  It may be a bit though.  I have 13 pipe sizes, around 20 lengths, and 3 different materials.  That was why I though content center editor would work easy.  I could set up one pipe size and just copy the rest and adjust everything as needed.
    CWW
    kcco
    Please use plain text.
    *Expert Elite*
    cbenner
    02-06-2013 12:24 PM in reply to: avaya2012
    This is what I generally do with geometrically similar parts.  I get one family built using i-parts (or whatever) and published.  Then I just copy that family to a new one and edit things like part numbers and material, descriptions etc.  Much faster if the dimensions stay the same.
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Active Contributor
    02-06-2013 02:28 PM in reply to: cwhetten
    Since you helped me out earlier maybe you can help me again.  I have everything set up and looking good except I have a non-unique file name somewhere.
    Does anyone have a good way of finding it in a table with about 980 rows?
    *Expert Elite*
    02-06-2013 03:18 PM in reply to: avaya2012
    You could try editing the table in excel and using the search / find tools.  980 is a lot of rows.  Not unheard of, but still quite a lot.
    Would you mind posting your iPart so we can take a look at it?  Since it sounds like this is your first attempt at creating iParts, someone may be able to offer some tips or advice.
    -cwhetten
